CathyC
#1 Posted : Saturday, April 4, 2009 12:33:46 PM(UTC)
CathyC
Has anyone experienced this: on a side-by-side 2-door refrigerator, the freezer sides where the door seals are - are very hot - I worry that they are hot enough to burn the rubber (or plastic?) seals.
#2 Posted : Saturday, April 4, 2009 5:52:49 PM(UTC)
CathyC
#3 Posted : Sunday, April 5, 2009 7:12:26 PM(UTC)
CathyC
Many thanks to DENMAN for a very quick response to my question. The answer was clear, the illustration showed exactly where the high temperature was at my refrigerator - and the recommended response was to clean cooling coils and to check the running of the fan. It turned out that the fan blade was "blocked" by a cardboard liner under the refrigerator - a corner of the cardboard had turned up and stopped the fan from turning. That fixed the problem !http://forum.appliancepartspros...images/smilies/smile.gif
