After about 5 -10 minutes gas seems to shut off , cleaned entire dryer and vent tube, replaced cut off and thermo kit 280010 where should I go from here ? ignitor or coils?
If the ignitor glows on and off but the valve doesn't open it's the coils. Normally you'll get 1-2 cycles of heat before the coils stop working.
Hope this helped.
Originally Posted by: MayTech If the ignitor glows on and off but the valve doesn't open it's the coils. Normally you'll get 1-2 cycles of heat before the coils stop working.
Hope this helped. i will try that thank you
