ts756
#1 Posted : Friday, August 17, 2012 12:55:14 PM(UTC)
ts756
Right side hinge pin has either broken or come out. The channel arms (both sides) seem to be seized to the door. This is the upper door and it has never been removed in 19 years. The manual says open door just enough to pull up on the door and it should come off. That's the way the bottom door works.
Any suggestions would be appreciated:confused:
Simon / APP Team
#2 Posted : Friday, August 17, 2012 1:42:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You should be able to pull the door off the hinges.That what the manual is saying.
Good luck.
Simon.
