The belt broke on our dryer and when Went to replace it, I noticed that the tension spring for the idler pulley was not attached at either end. I don't know where it is supposed to be attached to the motor assembly. Do you have any pictures showing where it is supposed to be connected?
Groups: APP Team
Hi.
Could not find the instructions, but as I remember one end of the spring hooks to the opening at the end of the idler arm and another to the base of the motor bracket or the machine base. Use the common sense.
Thank you.
Simon.
