fgo2
#1 Posted : Tuesday, August 14, 2012 2:29:10 PM(UTC)
fgo2
The upper oven broiler element will not heat up. The setting works fine, fan comes on but the element does not heat. I exchanged it with the one in the lower oven and the element is not the problem. Any suggestions on what to investigate next?
#2 Posted : Tuesday, August 14, 2012 3:28:51 PM(UTC)
If the Bake element works but the Broil does not then, most likely, the problem is a bad main relay board on the right side in the control compartment.
- The relay board Part number: 74006612
fgo2
#3 Posted : Tuesday, August 14, 2012 4:30:01 PM(UTC)
fgo2
Gene, Thanks for the prompt response. One more question, is there a method to test this board or is it just a replace and see item?
dmeekins
#4 Posted : Wednesday, August 15, 2012 11:10:02 AM(UTC)
dmeekins
My upper oven (upper burner only) stays on all the time after replacing my lower unit control board. It has never done this before. Suggestions.
#5 Posted : Wednesday, August 15, 2012 12:51:42 PM(UTC)
The only thing which can cause it besides the relay board is a broken wire between the relay board and the heating element.
#6 Posted : Wednesday, August 15, 2012 12:53:09 PM(UTC)
What is the complete model number of the oven and the part number of the new control board?
fgo2
#7 Posted : Monday, October 8, 2012 3:47:56 AM(UTC)
fgo2
Gene,
Finally getting around to ordering the replace the circuit board you recommended. Would it be prudent to order a thermostat at the same time considering I will have the oven out of the wall?
Thanks Frank
#8 Posted : Monday, October 8, 2012 1:44:32 PM(UTC)
Frank,
Which thermostat did you mean? Why this part become questionable?
fgo2
#9 Posted : Tuesday, October 9, 2012 8:08:56 AM(UTC)
fgo2
I am just thinking an older oven, older thermostat denegrating with time; when I am pulling out the unit to replace the board would it be best pratices to simply replace the thermostat on the upper oven. Perhaps I am being slightly anal.
Thanks for your input
#10 Posted : Tuesday, October 9, 2012 12:05:47 PM(UTC)
I don't think you have to do it at this time.
Guest (5)
