frig is collecting water inside under crispers,has to be removed twice a day.both frig and freezer appear to be working ok and you can feel air movement from fan in freezer area. could problem be a clogged drain tube somewhere.HELP:confused:
Your model number is incomplete so I cannot find any info on the unit. I am assuming it is a top mount (freezer) unit.
In any case it sounds like drain tube is plugged so that the water from the defrost cycle cannot drain into the drain pan.
Some units drain from a drip tray directly under the evaporator coils in the back of the freezer. Others drain from the freezer into a funnel like part at the top of the fresh food section and then out the back and down to the tray under the unit. I would check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end. You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tral after you are done.
Be sure to unplug the unit while doing this. |
THIS FORUM IS DEAD!!!!!!! |
