stardustvizslas
#1 Posted : Tuesday, August 14, 2012 3:51:21 PM(UTC)
stardustvizslas
We have a Frigidaire Gallery Dryer Stackable unit. The dryer spins but does not heat. I recently replace the drum belt and it has worked great for several weeks, but now is not heating.
Could this just be the heating element? I am wondering if it could be something else or a combination of things.
Jen in MI
#2 Posted : Thursday, August 16, 2012 1:52:34 AM(UTC)
I cannot find any info on the given model number. Tried at AppliancePartsPros and the Frigidaire site.
Please check it.
Model Number Locator
Yes it could be just the element but may also be a combination of things.
May even be just a power problem assuming that this is a 240 volt dryer. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
The best way to troubleshoot this is with a meter.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
