mikec205
#1 Posted : Monday, August 13, 2012 9:40:00 PM(UTC)
mikec205
I have replaced the heater element w/thermostat and defrost timer. Freezer still does not freeze and ice builds up on evap coils quickly. This problem started about 2 weeks after a repairman replaced a relay that failed(recall) - could that have anything to do with it or just a coincidence. what's left to replace? the freezer section is still much colder than the fridge side but not cold enough to freeze anything.
#2 Posted : Tuesday, August 14, 2012 12:51:43 AM(UTC)
With the freezer cold, turn the defrost timer till compressor turns off. If you get defrost, you have a bad defrost timer, or one that is not running if you failed to install it per directions that came with it.
mikec205
#3 Posted : Tuesday, August 14, 2012 8:37:43 PM(UTC)
mikec205
The compressor turns off when I turn the timer manually and still no defrost.
#4 Posted : Thursday, August 16, 2012 3:12:40 AM(UTC)
You probably have a bad wire in the defrost wiring, either that or a bad defrost timer.
Guest (4)
