tozbart
#1 Posted : Friday, August 10, 2012 3:30:53 AM(UTC)
tozbart
after cooking is done, fan motor won't stop, or sometimes after opening the door to remove food, when you shut the door the fan runs for while
disconnected plug, reset clock etc.
tried cooking again, same results.
Simon / APP Team
#2 Posted : Friday, August 10, 2012 1:43:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the door switches for the continuity (with one wire off).
If they checks OK - then most likely it's the control board.
Here are the breakdown diagram and Microwave replacement parts for General Electric JVM1660WB008 Counter top microwave | AppliancePartsPros.com
Thank you. Post the results.
Simon.
