vanj333
#1 Posted : Wednesday, August 8, 2012 3:11:18 PM(UTC)
vanj333
the dryer was hooked up. And the vent going out side had duct tape on it of course to keep bugs out. well it was not taken off I turned it on auto to dry. And very soon started smelling something burning took me a 2 to 3 min to turn dryer off really cant belive it did not blow up. I orderd the thermal fuse #3392519 and replaced still no heat.I need help do not know how to use digital mutimeter i purchesed today.
#2 Posted : Thursday, August 9, 2012 2:25:26 AM(UTC)
Replacement parts for Roper RED4340SQ1 29" ELECTRIC DRYER | AppliancePartsPros.com
There is a sticky at the start of this section on how to check parts and it has info on meter use.
Also here is my little blurb on using a meter.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Start with the heater itself. They are usually in the 8 to 12 ohm range.
If you find that the thermal cut-off (Item 6 in Section 1) has blown, then get back to us as there are other things you should check before replacing it.
Since you are a noob to meter usage I hesitate to include the following so if you do this be extremely careful. The meter should be set to AC volts usually the 750 volt scale.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
vanj333
#3 Posted : Friday, August 10, 2012 11:24:02 AM(UTC)
vanj333
Thank you very much for your advise sir. It was the heating element. Now I can get brownie points from the wife.
Have a gr8 day.
Vanj333
#4 Posted : Saturday, August 11, 2012 2:42:27 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Also glad to hear that you made some brownie points, they sure make life more enjoyable.
