Due to a power surge i had to replace my ADCII with a ADCIV, this included replacing the damper motor switch wiring from 2 to 1 connection when installing the new wiring harness. Now the damper motor constantly cycles open - close, etc. I know this will cause problems with the damper motor, please help...
The switch is connected properly to the connector that is farthest from the damper door motor.
Can someone please help I have been waiting for two weeks to get a reply my original post had one reply which was a question, i answered it and got no replies since 7/29, either the control board is bad, the temperature gauge isn't working or the damper motor is bad it just continously opens and closes, i have taken it apart 3 times now sometimes the defroster in the freezer quits working and the evaporator freezes up again. until i unplug it
Now the fridge light even quit!!!:confused:
