I decided to replace the ice container with it's auger because the original one was rusting. The freezer has no problem making ice.
I installed the new one and when the lever is pressed the motor runs and runs with just a few ice cubes coming out. The auger turns.
I can't figure out why the ice, which fills the container, will not spill out.
What is the complete model number of the refrigerator?
What is the part number of the new ice container?
The part number is 2315404 (ICE-CONTNR)
The model is 106-50594003.
Remove the ice bin and check the couplings (#16 & 25 at the attached picture). - The ice bin coupling Part number: 2220457
Is there a larger, clearer picture of how the blades and various other parts go together? Mine came apart!! Help!
