I just recieved the replacement parts for the rear bearing assembly (part #5303281153) and need step-by-step instructions to re-install the bearings, drum, and belt-pulley assembly. Do you have instructions and a schematic?
I have the same issue I just recieved the replacement parts for the rear bearing assembly (part #5303281153) and need step-by-step instructions to re-install the bearings, drum, and belt-pulley assembly. Do you have instructions and a schematic?
