I have a LG dehumidifier that has a couple problems. First, the control panel does not respond to the buttons when they are pressed. The humidity control is stuck at 70% and cannot be changed. Second, the unit does not turn run. The unit is plugged in and the control panel is lit up, currently showing 70% room humidity, but the fan and condenser never turn on. Is it worth fixing? If so, what parts does it need?
my LG dehumidifier is stuck at 70% also. how do i fix it?
