2 Pages12>
anna2012
#1 Posted : Tuesday, August 7, 2012 9:59:41 AM(UTC)
anna2012
Rank:: Member
Hi I recently replace the part W10177195 (control board) because certain buttons on my stove did not work. Unfortunately the replacement did not solve the problem. The following buttons just do not work: BAKE WARM FAVORITE TIMER OVEN LIGHT and all the Numbers 0 to 9.
Do I have to replace the membrane or is that a thermostat issue?
Simon / APP Team
#2 Posted : Tuesday, August 7, 2012 1:26:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The problem you are describing related to the membrane not the control board. Before replacing membrane clean the connector ribbon with isopropyl alcohol and pencil eraser.
If that doesn't help - replace the membrane.
Thank you.
Simon.
anna2012
#3 Posted : Tuesday, August 7, 2012 4:27:10 PM(UTC)
anna2012
Rank:: Member
Thanks so much for your tip. I just cleaned it with alcohol (not the pencil eraser - does this make a difference?) and no change. Unfortunately the same problem. So you suggest I have to buy a new membrane? I just want to be sure before spending $150 after just spending $200 on the new control board which was useless. Thanks again for any feedback since I am just hopeless....
Simon / APP Team
#4 Posted : Wednesday, August 8, 2012 8:52:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you got the control board from APP you may return it even if it's been installed.
Simon.
anna2012
#5 Posted : Wednesday, August 8, 2012 8:59:18 AM(UTC)
anna2012
Rank:: Member
Ok - Which part exactly is the problem (100% sure?) and can I buy it here on APP? Thanks
Simon / APP Team
#6 Posted : Wednesday, August 8, 2012 9:47:09 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the last digit of the unit's model number. The one you posted doesn't come up.
Simon.
anna2012
#7 Posted : Wednesday, August 8, 2012 10:00:48 AM(UTC)
anna2012
Rank:: Member
It is GW397LXUS4 - Maybe because it was sold to Panama the last digits change? Just an idea. Serial: DY0282106
Hope this helps
Thanks again
Simon / APP Team
#8 Posted : Wednesday, August 8, 2012 10:25:16 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
May be, but that no help. See if you can get the part number from the membrane itself.
Simon.
anna2012
#9 Posted : Wednesday, August 8, 2012 11:00:26 AM(UTC)
anna2012
Rank:: Member
On one of the 2 clear plastic "ribbons" i found the following numbers/ letters:
JN426653 REV A E140962
7450P113-115-60C USLN411557-109
Does this help?
Simon / APP Team
#10 Posted : Wednesday, August 8, 2012 1:09:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
No. This is not the Whirlpool part number. See if you can attach the readable picture of the control panel.
Simon.
Guest (4)
2 Pages12>
