ROUSD
#1 Posted : Wednesday, August 8, 2012 12:19:17 PM(UTC)
ROUSD
After using the self-cleaning cycle recently we've had problems with the controls. We can usually select the upper or lower oven (though occasionally selecting upper starts the lower one). We often cannot control the temps. Touching the control anywhere near either the up or down arrow causes the temps to dial down often continuing after removing your finger. I suspect the membrane in the control panel is the culprit, but wonder whether there's any maintenance I can do to restore things and also wonder whether it's possible that the microcomputer is bad, too.
Thanks--
Simon / APP Team
#2 Posted : Wednesday, August 8, 2012 1:05:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Because the control panel and membrane assembly is no longer available your only hope is to clean the flex ribbon connector edge with isopropyl alcohol and pencil eraser.
Simon.
ROUSD
#3 Posted : Thursday, August 9, 2012 3:41:39 PM(UTC)
ROUSD
Originally Posted by: Simon / APP Team Go to Quoted Post
... your only hope...
Thanks, Simon. I'll keep my fingers crossed.
Simon / APP Team
#4 Posted : Thursday, August 9, 2012 6:18:13 PM(UTC)
Simon / APP Team
Groups: APP Team
Post the results.
Simon.
ROUSD
#5 Posted : Wednesday, August 15, 2012 10:57:54 AM(UTC)
ROUSD
I tried alcohol, the eraser and even Deoxit. Nothing worked. Looks like it's time to look for some sales.
Thanks for the fast replies. I appreciate the help.
Simon / APP Team
#6 Posted : Thursday, August 16, 2012 9:08:18 AM(UTC)
Simon / APP Team
Groups: APP Team
Sorry to hear that. Next time we'll do better.
Simon.
