tsgroup
#1 Posted : Wednesday, August 8, 2012 9:21:26 AM(UTC)
tsgroup
We recently replaced our counter tops. I have a model C200 from 1981. The wires coming from the bottom of the stove top are all white. How do I tell which is positive and negative? A schema would be great.
Miguelito
#2 Posted : Tuesday, June 30, 2015 9:04:43 PM(UTC)
Miguelito
Duuuuude, u need to have a meter and check for 120 vac at the two hot leads. With an electric cooktop and downdraft there is not a positive and neutral. There are two hot leads and a chassis ground. Hire a proffessional electrician if ur scared bro. No shame.
Maytag power cable wiring help needed (Dryer Repair)
by snmb95 11/28/2014 11:57:29 AM(UTC)
