I have a GE Profile that all of a sudden decided to stop cooling. I checked and could not find any thing obvious. I replaced the capacitor, relay and overload after reading some info on the internet, but it still will not cool. The compressor gets cool, but never really changes. The fans run and the coils in the back of the freezer cools slightly but will not get cold. The mother board doesn't look burnt. I don't know what to try next.
Groups: APP Team
HI.
Open the freezer coils and check if they are covered with frost evenly or only in one corner.
Post the results.
Simon.
The freezer coil is not covered with frost. It will not even get cold. I worked fine one day then the next was 90 degrees inside.
Groups: APP Team
Hi.
Check if the compressor is running.You should fill the vibration and heat.Check if it's getting 120VAC from the control board. Provide the complete model number of the unit.
Simon.
Not really sure that the compressor is coming on. It never gets hot. The fan that cools the coils runs.
The model # is PSS26SGPASS.
Groups: APP Team
Hi. Remove the control board cover, locate on the left side of the control J8 of the 3 wire plug and J7 plug. With unit running check for 120VAC between J8 and J7 pin 9. No voltage - replace the control board Part number: WR55X10942
Follow the instructions, you may need to do some adjustments. Thank you. Post the results. Simon.
I checked the voltage as you suggested and there is 120V between the pins. The compressor does not seem to be turning on, just the fan is running. What do I check next?
Groups: APP Team
Hi. Check if there is 120VAC at the start relay overload. If yes - remove them (unplug the fridge) and check 3 compressor's pins for continuity and to the "ground" (any copper tube). If you have continuity between the pins and no continuity to the "ground" - replace the relay and overload. The overload Part number: WR08X10025
Well, I finally had a chance to check this. I have 0 volts at the start relay. I unplugged the connector and checked for voltage. I get 120 vac when I check to one half connected to the power cord, but when I plug it in and check voltage on the other side of the connector, I get nothing, checking all combinations across the connector. I also get 0 vac across the relay and the overload, so somehow I am not getting voltage to the compressor, even though the fan starts and runs. As I mentioned in the beginning, I just replace the start relay, overload and capacitor. Any ideas as to what to try next?
Groups: APP Team
Hi.
Sorry. It's not clear what and how do you measure the voltage. Please try to explain more clearly how you do it. Also, did you check the compressor contacts for continuity and ground? The condenser fan runs off the separate circuit (DC). With unit unplugged remove the control board and check it from the back for burns and bad soldering spots.
Simon.
