AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore 70 series washer will not spin or agitate
I have a Kenmore 70 series washer, model 110.20722990. I replaced the motor coupling about 6 months ago and washer worked great until recently. The washer will fill with water but the agitator will not spin at all. It used to freely spin by hand counter-clockwise but now it seems completely seized up. It will fill and drain, but no agitation or spinning at all.
Is this likely a transmission or clutch issue?
Groups: APP Team
Hi.
Does the motor run when it should agitate and spin?
Simon.
Yes, the motor is running. The agitator twitched, then nothing. But I can hear the motor and pump running.
The auger will spin clockwise (by hand) on top of the main agitator, but the dogs stop it from going counter-clockwise. Is this the normal behavior?
Groups: APP Team
Hi.
Yes it's normal. Check the coupling again.
Simon.
In taking the new motor coupling off, it appears as though the metal inner piece has broken loose from the plastic.Once that is off, I still cannot manually rotate the agitator blades in any direction. If the clutch or transmission froze up, could this piece have broken loose from that?
Groups: APP Team
Damn, was hoping it would be the clutch or something similarly cheap. I have the transmission out. Is there any way to look at it and identify if it is bad or the clutch or the brake?
Groups: APP Team
Grab the small shaft with a pair of pliers (where the coupling goes) and see if you can turn it without effort.
Jammed transmission should be replaced.
Simon.
Talked to a washer repairman today, he said a simple test of the transmission is to spin the coupler clockwise, the spindle should rotate back and forth as if agitating. If you spin the coupler counter-clockwise, the spindle should not move at all as that is the spin for the spin-cycle. Has anyone else heard of this?
I can spin the coupler by hand either direction, and the spindle alternates spins both ways.
Washer Repair
