glennjonesg
#1 Posted : Saturday, April 4, 2009 5:32:17 AM(UTC)
glennjonesg
When I set the dishwasher (2 hour cycle) to clean it will start, run for awhile and then stop....start, run for awhile and stop. After about 30 minutes it will flash "clean" although the bottom is still full of water. If I run rinse only, it will complete the cycle and empty all the water from the dishwasher.
#2 Posted : Saturday, April 4, 2009 7:00:38 PM(UTC)
Most likely the problem is a bad control board.
- The part number for the control board is AP4114333
Here are the break down diagrams and Replacement parts for MAYTAG MDB7160AWB | AppliancePartsPros.com
Dishwasher starts and stops then shuts off (Dishwasher Repair)
by mwindsperger 7/6/2009 7:19:48 AM(UTC)
