2 Pages<12
#11 Posted : Sunday, August 5, 2012 1:23:41 PM(UTC)
Without a meter, it will be hard to trace the problem, might want to replace it, it's a rather old unit, new ones are much more efficient, less chance of failure.
howieb38
#12 Posted : Sunday, August 5, 2012 2:09:43 PM(UTC)
howieb38
Rich, is there any way to replace the compressor and associated items and keep the refrigerator and freezer?
#13 Posted : Monday, August 6, 2012 12:30:26 AM(UTC)
First I would verify you have a problem with the compressor start components. If you suspect them, then replace them with the URO41 device.
howieb38
#14 Posted : Monday, August 6, 2012 2:39:17 AM(UTC)
howieb38
A bit more info Rich. This morning when the unit went dead, just like before, no lights, nothing.
I took my meater and measured the AC voltage at the overload and PTC relays, both showed no voltage. After a few minutes of waiting I heared a slight click from somewhere and the voltage returned and the unit came back to life. The compressor started normally.
Is there some other voltage cut off device in these units?
HB
#15 Posted : Monday, August 6, 2012 2:57:54 AM(UTC)
There is no shutoff in the fridg that would interrupt power. I would start at the wall outlet, then check for missing voltage at different places in the fridg.
If there is a control panel connector, I would disconnect it and spray with non-residue contact cleaner available at Wall Mart.
howieb38
#16 Posted : Monday, August 6, 2012 4:41:49 AM(UTC)
howieb38
I'll keep checking Rich. Thanks for all the help.
howieb38
#17 Posted : Saturday, August 11, 2012 8:29:37 AM(UTC)
howieb38
Hi Rich:
FYI. When it would shut down, I found that when I pushed on the outside of the on/off switch it would sometime start up again.
I pulled the AC plug and inspected the four contacts on the on/off switch. I found that one contact (all four contacts use a quick disconnect system) had signs of being burnt and somewhat corroded with black residue. Remember this unit is 12 years old, so it could have been building up since new.
I replaced that quick disconnect plug, cleaned all four contacts, insured that all four were making good contact, and fired it up.
So far the problem seems to have been cured. I suspected that because it was so intermittent, it would turn out to be something weird like this. I wanted to pass it on for your knowledge base.
Again, thanks for all the help Rich.
Howie Burch
#18 Posted : Sunday, August 12, 2012 12:21:46 AM(UTC)
Very good, I thought it would be something like this.
2 Pages<12
