Surface burners work fine. Bake igniter does nothing, broil igniter glows but does not light broil burner. What could be my problem?
Groups: APP Team
Hi. Most likely both ignitors are bad. Check the bake one for the continuity. Check the broil for the current draw. If it's less then 2.5amp - replace it. Both ignitors are the same Part number: WB2X9154
