it will make ice the tray is full but when i put the cup on the door to get the ice nothing will come out
when you push the dispenser for the ice, do you hear any noise? You should hear a small click noise when you push the dispenser which is the click of the tiny micro switch that sends power up to the ice auger motor to dispense ice. Need more info to help to properly diagnose.
when you push the ice dispenser it makes a humming noise. i took the ice tray out and there was ice stoping it from turning so i took all the ice out and clean it up so nothing was there, it started to work then just stoped
