RHonda Pitts
#1 Posted : Wednesday, August 1, 2012 12:50:36 PM(UTC)
RHonda Pitts
Whirlpool duet dryer gew9200lw1
:mad:
the diagnostics won't come up now it did flash an e3 code 1 time
When the dryer was disassembled for testing and then reassembled the unit worked one time and then it was back to dead.
do I need the control interface or the main control module?
everything else tested out fine I would appreciate knowing which part to purchase
thanks
#2 Posted : Wednesday, August 1, 2012 5:25:15 PM(UTC)
Perform the test #5 as instructed in the attached Tech sheet (page 6) and post the results.
File Attachment(s):
Tech Sheet - 8541833 - GEW9200LW1.pdf (327kb) downloaded 21 time(s).
