2 Pages<12
#11 Posted : Wednesday, April 1, 2009 3:28:52 PM(UTC)
hvach3-1,
Check all infinite switches. Make sure the Black wire is connected to the "L1" terminals and the Red wire is connected to the "L2" terminal for all switches.
Double check the wiring for the rocker switch. There are two pairs of contacts. Using an Ohmmeter, find which pair is closed in each position of the switch. Make sure that the black wire and two blue wires are connected to one (blower) pair and the two white wires and two brown wires are connected to another (oven light) pair. The picture attached.
File Attachment(s):
Rocker switch S136.doc (28kb) downloaded 21 time(s).
hvach3-1
#12 Posted : Wednesday, April 1, 2009 5:32:44 PM(UTC)
hvach3-1
It's a three wire setup. Thanks for all your time, but notice I junked this stove, no joke. Thanks again.
hvach3-1
#13 Posted : Friday, April 3, 2009 2:12:04 PM(UTC)
hvach3-1
Dumped the stove and purchased a 2 year old one. Removed the back cover, plugged in stove, checked voltage @ terminal block on stove, 220v L2 to N. Went to breaker panel and traced out N, It was just stuck on the screw, not tightened at all. Tightened up and all is well. Read correct voltage @ recepticle, I guess when a load was applied the N couldn't carry it and L1 back fed. I don't totaly understand it, but that's the low down. Thought it might help someone out in the future. Thanks again to those who tried to help me.
#14 Posted : Friday, April 3, 2009 2:34:46 PM(UTC)
Thank you for letting us know.
Am always interested in the weird, pain in the rump problems and solutions.
Can never tell when something like this will plague someone else.
By the way CONGRATS on finding it.
2 Pages<12
