I Have A Ge Zoneline Az26e12dacv1 The Controls Don't Work When You Plug It In The Heat Comes On And You Have To Unplug To Shut It Off. It Has 3 Circut Board Which Are Expensive I Order The Switch Aux Which Is The Cheapest
Stuck relay, would have to troubleshoot it with the wiring diagram and a multimeter.
