HI Verdana Freezer will not cycle to off. Replaced T STAT from Appliancepartspros.com. Temperature drops to -20 Thats 20 below zero. I unplug freezer to stop. T Stat is set AT 1 setting. Freezer cannot be set at any number lower. What do I need to fix.
What is the part number of the thermostat you already replaced?
Originally Posted by: ApplianceJunk  What is the part number of the thermostat you already replaced? Part#WPF24B-L Recieved from 2W3468
