chasepawpaw
#1 Posted : Thursday, July 26, 2012 8:33:02 AM(UTC)
chasepawpaw
Maytag Atlantis washer (MAV6200AWW) stops when it gets to the extra rinse cycle. I have to manually advance timer to pump out extra rinse water. Is this a bad timer?
sidfink43
#2 Posted : Friday, July 27, 2012 5:02:50 PM(UTC)
sidfink43
If it stopped after washing it could be the lid switch, but since it goes all the way through to filling on the second rinse it does sound like the timer.
MayTech
#3 Posted : Friday, July 27, 2012 11:16:30 PM(UTC)
MayTech
Make sure the "extra rinse" option button is pushed in all the way... i've seen them get stuck half way in and do funky things, If that's ok then it's probably a bad timer.
