AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Estate Electric Dryer won't start - Checking continuity on Timer switch?
Dryer will not start. Door light turns on when door is open/off when closed. Thermal fuse is closed/good. Start relay switch is closed/good. I haven't checked the door switch yet nor the timer switch. The timer does sound like it is running. Which wires on the timer switch should there be continuity and does it matter which setting it is on?
Thanks for the help.
Rank:: Advanced Member
Groups: APP Team
I have continuity on the door switch. On the timer I have continuity between BK-BU but not T-W. Does this mean the timer switch needs replaced?
Thanks for your help
Groups: APP Team
Hi. Just to prove the point install temporary jumper wire on T-W. Here is the timer Part number: 3979617
Thank you. Post the results. Simon.
I jumped T-W and the dryer started. I'll install a new timer switch. Thanks for your help.
Groups: APP Team
You are welcome. Good luck.
Simon.
Dryer Repair
