ice builds up on freezer floor als water leaks on floor in front
:confused: Originally Posted by: donzell ice builds up on freezer floor als water leaks on floor in front
Groups: APP Team
Hi.
You will need to open the rear panel in the freezer and defrost and clean the condensate drain. Use the blow dryer, hot water and a lot of patience. Turn the fridge off while doing that.
Thank you. Post the results.
Simon.
