The Fan shuts off after 15 minutes with nothing on--just venting. It also shuts off when with the grill on. Blower motor is hot. I have taken off the restrictor plate.
I just replaced the blower motor and fan wheel. It does exactly the same thing. Did not fix the problem.
Any ideas would be greatly appreciated.
could relays or switch cause this??
Groups: APP Team
Hi.
There is a restriction in the air flow. Check the vent and the flapper.
Thank you. Post the results.
Simon.
