mtbike
#1 Posted : Monday, June 18, 2012 6:19:44 PM(UTC)
mtbike
I believe I need to replace the magnetron. Can someone direct me to some directions on how to get at it. I need some directions before I purchase a new one.
The microwave shuts down in 3 sec , but if I put it a 0 power it will run forever. I read here that it may be RF leakage from the magnetron
Thanks for your help
MikeB.
#2 Posted : Tuesday, June 19, 2012 5:27:19 PM(UTC)
Hi Mike,
You have to remove the microwave from the oven cabinet first. The instructions are attached to the reply.
- The magnetron Part number: 4375072
Here are the breakdown diagrams and Replacement parts for Whirlpool GMC305PDQ2 ELECTRIC OVEN/MW COMBO | AppliancePartsPros.com
File Attachment(s):
Removing the microwave.doc (1,141kb) downloaded 40 time(s).
Removing the magnetron.doc (907kb) downloaded 39 time(s).
mtbike
#3 Posted : Monday, July 23, 2012 5:28:18 PM(UTC)
mtbike
OK, so the symptoms are: microware runs and heats for 3 sec and then shuts off as if the door was opened. If the microwave is on 0 power, it will run forever. It is only when the magnetron kicks in that the unit will turn off
I replaced all 3 door switches and the magnetron. I checked the magnetron thermal switch and it is good. I am tired of throwing parts at this thng, but what else could it be. Next I was going for the capacitor. Any help would be appreciated.
MikeB.
Simon / APP Team
#4 Posted : Tuesday, July 24, 2012 9:22:49 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Did you check if the magnetron fan is working?
Also, check the cavity and magnetron thermal fuses when the microwave stops working.
If everything check out OK - then most likely it's the relay in the control board.
Thank you.
Simon.
mtbike
#5 Posted : Tuesday, July 24, 2012 10:07:36 AM(UTC)
mtbike
Simon - Thanks for the reply. Yes, the blower motor is working. I did verify the magnetron thermal cut-off is working (actually cuts off at about 170F - 180F Vs the 145F per spec). I did not verify the cavity thermal cut-off.
What would cause the relay to cut out? Most relays will fail to pick or fail to release. In this case, it will pick for 3 sec and then release.
Also, it seems that after I have worked on the unit, when I first power it up, all is good. I have run the unit for 10 mins w/o any issues (I put a few cups of water water in the microwave and it heats up just fine) It is the next day that it starts acting up again.
MikeB.
