rosygt
#1 Posted : Thursday, April 2, 2009 3:49:34 PM(UTC)
rosygt
After completing wash and rinse cycles, the water gushes out of the lower front part of the door right next to where the control wires enter the bottom of the machine. Found and removed a small piece of plastic that was clogging drain line, but it still is leaking. The after wash cycle water is enough to fill a 2 quart saucepan.
applianceman
#2 Posted : Thursday, April 2, 2009 4:11:52 PM(UTC)
applianceman
[FONT='Times New Roman']Your saying its leaking from the door right? If so there could be a hole in the wash arm causing water to spray under the door. There is a filter under the wash arm there could be a hole in it or it may not be lying flat causing the same thing. Also sometimes I see them leak through the soap dispenser on the door. Dishwasher Leaking Repair Guide [/FONT]
#3 Posted : Friday, April 3, 2009 1:22:57 AM(UTC)
Replacement parts for FRG FDB2810LDS0 | AppliancePartsPros.com
Check this out from TechnicianBrian's website
<title>Frigidaire Dishwasher Leaking from the Door
Seems like an awful lot of water.
Is water being left in the bottom of the tub perhaps this is causing an overfill due to poor draining.
frigidaire Dishwasher Leaking (Dishwasher Repair)
by LM84 9/24/2014 11:00:12 AM(UTC)
Frigidaire Dishwasher Leaks Hours After Cycle (Dishwasher Repair)
by barnold99 5/23/2012 6:54:22 PM(UTC)
Frigidaire Dishwasher Leaking From Side (Dishwasher Repair)
by SBorg 5/3/2012 5:25:56 AM(UTC)
Frigidaire Dishwasher Leaking Bottom of Door (Dishwasher Repair)
by MLipovsky 11/20/2011 10:59:57 AM(UTC)
Frigidaire Dishwasher Leaking at door bottom (Dishwasher Repair)
by tombush 4/18/2011 8:35:18 PM(UTC)
Frigidaire DishWasher leaks from bottom (Dishwasher Repair)
by four2699 12/13/2009 9:49:47 AM(UTC)
