clay1732
#1 Posted : Thursday, April 2, 2009 6:58:47 AM(UTC)
clay1732
Washer fills with water then does nothing. I have check the door switch for continuity and it appears to be working. i can advance the timer switch manually and still the washer does not work. Any help is greatly appreciated!
magician59
#2 Posted : Thursday, April 2, 2009 2:03:39 PM(UTC)
magician59
After it fills, can you set it on spin and drain it?
clay1732
#3 Posted : Friday, April 3, 2009 5:02:58 AM(UTC)
clay1732
No it will not do anything, but fill with water.
