RLasher
#1 Posted : Friday, July 20, 2012 7:56:55 AM(UTC)
RLasher
Dishwasher problem that could be either the "Console Assembly" or the "Electronic Control" - I can't tell which. Please help.
Here is a sequence for my dishwasher:
+ door open a little - little green "Clean" light is "On" (normal)
+ close door - little green light goes "Off" (normal)
+ push "Time Saver" button
- "Time Saver" light comes "On" (normal)
- washer starts right up (never pushed the "Start" button - not
normal!!)
- "Sensing" light comes on (normal after "Start" button pushed)
- display shows "_J" instead of the normal "40"
* the "_" doesn't look like the horizontal segment in a "4"
* the "J" could be 3 segments of a "0".
- "Cancel" doesn't work
- "Start" button does nothing
+ After the washing cycle started, the "_J" turned into two vertical bars
- one bar on the lower left that could be part of "0"
- one bar on the upper right the could be part of "0" or "1"
+ When the washing cycle was done, the display changed to a single
vertical bar on the upper left.
+ washer appears to work normally. Had almost no dishes in it because
of testing - the washing cycle sounded normal but the drain cycle
might sound different - the washer was drained when it was all over.
The "Clean" light was "On" like normal.
Both the "Start" and the "Cancel" buttons have the normal tactile feedback.
At the beginning of the running, I opened the circuit breaker, waited a minute, and close it. The washer resumed its work from where it left off.
I assume that the problem can not be in the "Dual Digit Display" because that would not cause the skipping of the "Start" button and the "Cancel" to not work. But is it the "Console Assembly" or the "Electronic Control". Please help.
#2 Posted : Saturday, July 21, 2012 2:17:30 AM(UTC)
Replacement parts for Kenmore 66515929001 | AppliancePartsPros.com
It does sound more like a control(AP3775506) problem than a keypad problem.
The normal way to troubleshoot is to check the keypad with a meter.
Then if the keys check out OK replace the control board.
Still a bit of a crap shoot but your odds are better.
The tech sheet shows the keypad wiring.
It is a matrix type so the polarity of the meter is important when you check the keys.
If you need some help with this just post a reply.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
File Attachment(s):
15929001.pdf (172kb) downloaded 3 time(s).
