krzy1957
#1 Posted : Friday, July 20, 2012 1:04:14 PM(UTC)
krzy1957
Help :confused:
The ice maker will not fill. The water dispenser works fine.
I do have power at the selenoid. Tried removing filter no luck.
Simon / APP Team
#2 Posted : Friday, July 20, 2012 2:47:10 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if there is 120VAC to the icemaker.
Try to switch the plugs at the water valve and press the water lever at the fountain. If the icemaker fills up - replace it.
If not - check the solenoid coil for continuity. Open - replace the water valve.
Check if the inlet tube is frozen. If it is - replace the water valve.
The icemaker Part number: WR30X10093
The water valve Part number: WR57X10055
Here are the breakdown diagrams and Replacement parts for General Electric PFS22SISCSS BOTTOM MOUNT REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Ice maker won't fill with water automatically (Refrigerator & Freezer Repair)
by tracymckibben 9/8/2016 6:19:30 PM(UTC)
Ice maker won't fill with water (Refrigerator & Freezer Repair)
by arctic123 12/6/2012 5:26:07 PM(UTC)
ice maker won't fill with water (Refrigerator & Freezer Repair)
by bettyjoe 10/27/2011 10:24:50 AM(UTC)
Whirlpool Ice maker won't fill (Refrigerator & Freezer Repair)
by LabTech 8/3/2009 12:26:08 PM(UTC)
by 17929 8/14/2008 2:34:33 PM(UTC)
