I need to replace the inner oven door glass. how do you remove the door to access this. Any other tips?
Groups: APP Team
Hi.
Look at the new hinge. There is a small metal rod inserted in the hole preventing the hinge to close. Use a short screws to block the hinges while the door is open. Then grab it at the sides and lift it out from the body.
Thank you.
Simon.
