hendrix
#1 Posted : Tuesday, July 17, 2012 6:07:01 PM(UTC)
hendrix
I now own my first house and I am a novice at appliance repair. I have been searching the internet trying to learn how to use my digital multimeter and trouble shoot the problem that I am having. The freezer is only cooling to 38 and the fridge to 42. There is no frost buildup on the coils and the gasket seals are good. The compressor is running and there is no clicking on the relay. The condenser fan is not coming on at all.
I applied the leads of my DMM to the terminals of the compressor. I went 1 to 2 then 1 to 3 then 2 to 3. Every reading was 0. When I went from the terminals to the metal compressor cover I got the reading of 1. The compressor and start really get very hot when running. Too hot to leave your hand on for more than a second or two. I don't know where to go from here. Any help would be most appreciated.
Cheers,
Dave
#2 Posted : Wednesday, July 18, 2012 1:25:34 AM(UTC)
Groups ready for retrieval: Senior Expert
I would put a portable fan on the compressor and condensing coils. After the compressor cools down, measure the freezer temperature,should be below 10 degrees.
#3 Posted : Wednesday, July 18, 2012 3:25:48 AM(UTC)
The following may help with your meter usage.
http://forum.appliancepartspros...continuity-ohmmeter.html
Here is my blurb on it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
[COLOR="Blue"]Every reading was 0. When I went from the terminals to the metal compressor cover I got the reading of 1[/COLOR].
You probably got 0 because you were using too high of a meter scale so the meter cannot resolve the low resistance. Just does not have enough digits so it rounds it off and 0 is the closest round off.
1 is infinite resistance (open). This is what you would see when you turn the meter on and the meter leads are not shorted together.
When checking for a short to ground use a mid rage meter scale 2K (2,000 ohms) or so.
