schmocker
#1 Posted : Monday, July 16, 2012 1:17:00 PM(UTC)
schmocker
Hello,
My Roper REX4635EW0 is not heating up during any of the cycles which use heat. I have replaced the heating element with Item Number AP3094254 from appliancepartspros.com and had marked all connections before uninstalling the old for the new so as to make sure my connections were done correctly. I then tested the dryer and still no heat. I just replaced my Hi - Limit Thermostat with Item Number AP2973862, and my Dryer Cycling Thermostat with Item Number AP3131939 which I also bought from appliancepartspros, and installed them in the same method as described above for the heating element, so as to ensure all connections were in their correct place, and I still have no heat. :-(
The only part I have yet to replace that, as far as I can tell, has something to do with the heating is Item Number AP3094244 referred to as the Dryer Thermal Cut - Off Kit which apparently consists of 1 Hi - Limit Thermostat (which I've already replaced), and 1 Thermal Cut - Off (the part pictured on the right in the website description photo).
My question then, is the following two part query:
A) Are there any other parts responsible for heat that I am not thinking of aside from the Thermal Cut - Off?
and B) If the Thermal Cut - Off installed in my dryer now is in fact "bad", would that actually prevent the dryer/element from heating up?
I realize I may have gone about repairing this dryer in a long, and round about way, rather than just testing parts with a continuity tester or some other testing equipment, but had no access to such testing items. Any help you can offer up would be greatly appreciated!! Thanks, schmocker
#2 Posted : Thursday, July 19, 2012 3:13:21 AM(UTC)
See the attachment for the tech sheet
[COLOR="Blue"]A) Are there any other parts responsible for heat that I am not thinking of aside from the Thermal Cut - Off?[/COLOR]
Yes, See the wiring diagram. There is a centrifugal switch (2M/1M) on the motor that closes when the motor gets close to operating speed. This ensures that the heater does not come on until there is air flow. Also see timer contacts Timer Switch 2.
Also have you checked the power (240 volts), see below.
[COLOR="Blue"]
B) If the Thermal Cut - Off installed in my dryer now is in fact "bad", would that actually prevent the dryer/element from heating up?[/COLOR]
Yes. If there is a thermal run away the hi-limit opens/closes and starts regulating the temperature. It is a safety device so is not designed to run all the time eventually it's contacts fail. If they weld together then the thermal cut-off blows as a secondary safety.
[COLOR="Blue"]I realize I may have gone about repairing this dryer in a long, and round about way, rather than just testing parts with a continuity tester or some other testing equipment, but had no access to such testing items.[/COLOR]
I would still consider getting a meter, see below. It is not unheard of to get a bad replacement part. If you install it without checking that it is OK you could go on forever in a circle trying to fix the unit.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
There is another safer way to do this but it assumes that the heater and centrifugal switch are OK. I would try this first. Put the unit mid scale in an auto cycle Turn it on, if the timer advances then you have 240 as the timer motor gets power from the 240 volts when the heater is off.
If it does not advance then you will have to measure the voltage.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
REX4635.pdf (126kb) downloaded 5 time(s).
