i have a janitrol central air unit. it cools good, but after running for awhile the the fan on the outside unit stops turning and i have to shut it off for 10 minutes before it will turn again. is my fan motor bad?
Groups: APP Team
Hi.
Check the run capacitor. If it's good - replace the motor.
Thank you.
Simon.
how do i check to see if capacitor is good?
Groups: APP Team
By using the multimeter or replacing the capacitor.
Simon.
i replaced my copasitor & motor. now my unit vibrates terribly and won't cool below 83 degrees. what may cause this?
Groups: APP Team
Hi.
Improper installation of the motor and /or the fan blade.
Simon.
