MCH_STL
#1 Posted : Thursday, July 12, 2012 3:20:18 PM(UTC)
MCH_STL
Hello. I have a gas dryer that runs but does not have heat. I took apart the dryer & started it, but I did not see the ignitor light up or glow. I checked the following parts with a continuity tester (everything works):
-Thermal fuse
-Ignitor
-flame sensor
-Start switch
Also:
-Removed gas line that connects to the wall - did smell gas
-Checked the breaker, it didn't appear to be tripped; switched on and off anyway
-Checked the dryer vents - no build-up
Please help! Thank you.
#2 Posted : Thursday, July 12, 2012 3:27:41 PM(UTC)
Did you remove the wires from the parts you've tested for continuity before you tested them?
MCH_STL
#3 Posted : Thursday, July 12, 2012 3:31:54 PM(UTC)
MCH_STL
Yes, I did remove the wires before testing.
#4 Posted : Thursday, July 12, 2012 3:43:00 PM(UTC)
Does the igniter glow?
If it does then most likely the problem is a bad gas valve coils.
- The coil kit Part number: 279834
Part number: 279834
MCH_STL
#5 Posted : Thursday, July 12, 2012 3:58:00 PM(UTC)
MCH_STL
I just double checked, and the igniter is not glowing.
MCH_STL
#6 Posted : Friday, July 13, 2012 9:49:20 AM(UTC)
MCH_STL
Just checked the thermal cutoff fuse, it has no continuity. Could this be the problem?
#7 Posted : Friday, July 13, 2012 4:46:28 PM(UTC)
Yes, if it has no continuity then this is the culprit.
- The thermal cut-off kit Part number: 280010
Part number: 280010
MCH_STL
#8 Posted : Friday, July 13, 2012 5:05:28 PM(UTC)
MCH_STL
It was the thermal cut off fuse. I purchased a replacement this morning, and everything works great.
#9 Posted : Friday, July 13, 2012 5:17:37 PM(UTC)
I'm glad to hear it. Good job!
