buckley.l
#1 Posted : Wednesday, April 1, 2009 5:17:52 PM(UTC)
buckley.l
My washer does not spin and when I took it apart the bearings were at the bottom of the washer. I order a lip seal kit. Does the kit come with a front and back seal?
#2 Posted : Thursday, April 2, 2009 5:28:36 AM(UTC)
Replacement parts for MAYTAG MAH5500BWW | AppliancePartsPros.com
If you click on the picture in the list another view opens showing what comes in the kit.
neptune help
#3 Posted : Thursday, April 2, 2009 2:53:17 PM(UTC)
neptune help
Check out NEPTUNE BEARING for more Neptune bearing and seal kits. They also rent a custom tool kit to help you change your bearings.
Don't forget to change your faulty door latch wax motor if you have a Maytag Neptune MAH3000, MAH4000, MAH5500A or a 2000 stacker. See MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR for more details.
Guest (4)
