2 Pages12>
stamfordmike
#1 Posted : 13 years ago
stamfordmike
I have a top freezer, that drops of water have been coming from the upper part of the fridge, some of it collects in a cup I put in and the rest fall down to below the crisper into a pool of water. The fridge and freezer work fine, but it's annoying to dry up the water under the crisper every day. I've looked around the forum and now see that it's most likely that my defrost drain is plugged.
I looked in the freezer for the drain and couldn't find any small circle and the component in the fridge doesn't easily pop off and I don't want to mess with the styrofoam in it either.
Can someone tell me how to get to the defrost drain in a whirlpool fridge Model ET20GKXFW00, Serial EGO711114, mfg dATE fEB 1997.
Do I need to pull it out and look from the back? Any suggestions on how to get to it so that I can put hot water down it to fix it would be great.
I've already vacuumed the dust from the coils and the drip pan was dry.
Thanks in Advance
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Look at this diagram under #7 - it's the drip pan. The opening you are looking for is in the middle, covered by ice.
Use the blow dryer, hot water, compressed air and a lot of patience.
Here is the diagram Unit replacement parts for Whirlpool ET20GKXFW00 REFRIGERATORS AND FREEZERS | AppliancePartsPros.com
Good luck .Post the results.
Simon.
stamfordmike
#3 Posted : 13 years ago
stamfordmike
when you say diagram #7 there is only 5 diagrams, again at little more precise detail on where the hole/drain is, would be great, thanks. Again I'm trying to figure out where to get access to the defrost drain
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
What I meant was part #7 on the diagram #5.
Thank you.
Simon.
stamfordmike
#5 Posted : 13 years ago
stamfordmike
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Thank you.
Simon.
Thanks but how do I get to part 7? I can't tell from the diagram. Do I need to pull the fridge out and uncrew the back to get to it? Unscrew the liner in the freezer, or somewhere in the fridge? How would I go about getting to part # 7
Thanks again
Simon / APP Team
#6 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Remove the back panel inside the freezer and you will see the evaporator.
Simon.
stamfordmike
#7 Posted : 13 years ago
stamfordmike
thanks, should I have the fridge plugged in or would you suggest I unplug the fridge as well.
Simon / APP Team
#8 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Unplug the fridge while you are working on it.
Simon.
stamfordmike
#9 Posted : 13 years ago
stamfordmike
Well this Saturday I unplugged my fridge and defrosted the freezer, after a few hours I was able to get to the hole, there was ice around and in the hole. So I assume that was the issue. I put a bunch of hot water down there and heard it go into the drip pan. I bent some of the coils but I think that was the only damage, hopefully I fixed it, I guess I won't know for a few days, thanks again for your help
Simon / APP Team
#10 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
2 Pages12>
