Well, first thanks for all the help here. Secondly, I replaced the clutch in a Kenmore series 500, mod. 110.28522701. Now, no power, only water intake. The wall socket has been tested with a known good device and the device runs. I dont feel a lid switch under the right hinge wire that should be part of the lid switch. Could it have fallen off? I notice the lid switch part requires a screw. And, is the lid switch on the right or left. Thanks again. Biglakebubba.
Groups: APP Team
Hi. The lid switch on this model is on the left.You can test it by jumping two outer wires. The lid switch Part number: 8318084
Thank you. Post the results. Simon.
