2 Pages<12
TigerDriver
#11 Posted : Wednesday, July 11, 2012 7:04:37 AM(UTC)
TigerDriver
Despite the LED not behaving as documented (i.e., it never stops blinking), I woke up this AM to a full ice receptacle, and the optical system detects that it's full. Comment?
Also, after I replenished the freezer with food, and let the freezer cool to zero, the added thermal mass causes the freezer to return to zero degrees almost immediately after the door is open.
WRT to the control board at #19 on the diagram: could you please tell me how this board is labeled on the schematic?
Joe
#12 Posted : Thursday, July 12, 2012 12:45:12 PM(UTC)
Hi Joe,
Looks like everything works fine. I can not explain such LED behavior but I don't think that you should do anything as long as the fridge performs fine.
This control board is labeled as "electronic control" on page 2.
TigerDriver
#13 Posted : Thursday, July 12, 2012 3:05:14 PM(UTC)
TigerDriver
Gene,
I don't intend to; a spooky fix is better than no fix at all. Thanks for your help.
#14 Posted : Thursday, July 12, 2012 3:10:52 PM(UTC)
You are welcome. Good luck with your fridge!
2 Pages<12
