KentSmith
#1 Posted : Wednesday, April 1, 2009 12:00:00 PM(UTC)
KentSmith
Where does the Piston & Nut go when replacing the Check Valve?
applianceman
#2 Posted : Wednesday, April 1, 2009 1:52:47 PM(UTC)
applianceman
Open the dishwasher and look at the back in the bottom of the tub. You should see a filter (screen) remove it. Under the filter is were the piston and nut is located. Using a pair of piers unscrew the old one and screw the new one back in and you’re good to go. Hope this helps.
http://www.appliance-repair-it.com/dishwasher-repair.html
KentSmith
#3 Posted : Wednesday, April 1, 2009 2:58:15 PM(UTC)
KentSmith
Thank you.
