Manual states that the fan should run at LOW when the microwave is in use and should switch to HIGH only when the temperature around rises to a certain level. Is this fan a cooling fan separate from the VENT FAN? The Vent Fan runs normal at LOW and HIGH with the button on the touch pad. Which component could be defective? How can I get hold of a schematic/wiring diagram?
