Dondopei
#1 Posted : Wednesday, July 11, 2012 8:12:53 PM(UTC)
Dondopei
Hello,
I am having a problem with my dryer. I have checked the two thermostat, and flame sensors for continuity and they are good. The igniter glow when started. When I check the two solonoids on the gas valve, only the first solonoids operates when I first turn on the dryer. I am not sure what needs to happen for the second solonoid to activate. I tested the second solonoid and it works if it gets power to it. Need some expect help on this. Also, I looked for the thermistor and thermo fuse but cannot locate them.
Thank you
Dondopei.
#2 Posted : Thursday, July 12, 2012 2:44:22 PM(UTC)
Hi Dondopei,
Your dryer actually is made by LG. LG does not sell the coils separate and you have to order the whole gas valve assembly.
- The gas valve assembly Part number: 5221EL2002A
