Hello,
My dishwasher is leaking water where hose #37 on the parts diagram goes into the fitting on the side of the tub. The hose isn't split. Is there a filter in the fitting or?? Any help would be greatly appriecated.
Thanks,
Andy
Hi Andy,
It can happen is there is too much pressure in the incoming water line. Try to play with the water shut off valve under the sink to lower the pressure.
