brittlediabetic
#1 Posted : Friday, June 29, 2012 10:41:12 AM(UTC)
brittlediabetic
Microwave runs 3 seconds & shuts off. Checked magnetron for continuity; no burned or severed wires visible anywhere. Please HELP!!!! Mrs. is very upset!!!!!!!!!!!!!!!!!! Thanks (unit still looks new)
TelcoNut
#2 Posted : Tuesday, July 10, 2012 12:29:50 PM(UTC)
TelcoNut
Hello: I have had that problem and have fixed it by replacing one of the 3 saftey Mico Switches on front door. I believe it is the top one that causes the 3 sec shutdown. Very easy to replace after turning off power, take cover off and without taking the door assembly apart the top switch can be replaced by lifting the little plastic retainer and pushing switch to the side before lifting out.
Panasonic 1250W microwave oven (Microwave Repair)
by Guest 11/7/2021 5:13:30 AM(UTC)
Panasonic Genius Prestige turntable runs when door is opened (Microwave Repair)
by Lost in the ozone 11/30/2019 7:21:27 AM(UTC)
Panasonic NNT655SF Try's to start but clicks off? (Microwave Repair)
by rebar 12/20/2016 4:20:52 PM(UTC)
Panasonic (Microwave Repair)
by Azcona 8/3/2016 4:01:15 PM(UTC)
Panasonic microwave resets after a few seconds on 'sensor cook' (Microwave Repair)
by Bev-Ann 6/1/2014 10:15:31 AM(UTC)
Panasonic oven shuts off NN-SA651S (Microwave Repair)
by ladybridgeport 4/23/2014 10:49:07 AM(UTC)
Panasonic Microwave turns off after 3 seconds (Microwave Repair)
by billy_1337 1/15/2013 2:09:51 PM(UTC)
Over Range Panasonic Microwave (Microwave Repair)
by nogloff 11/23/2012 8:17:01 PM(UTC)
panasonic inverter microwave (Microwave Repair)
by pawtastic 2/25/2012 8:47:18 AM(UTC)
panasonic microwave (Microwave Repair)
by brokenpanasonic 1/23/2012 11:43:50 AM(UTC)
panasonic microwave cooktop light (Microwave Repair)
by ch1894 11/28/2010 3:35:06 PM(UTC)
Panasonic microwave turntable turns when door opened (Microwave Repair)
by nightdog 2/6/2010 6:27:40 AM(UTC)
Panasonic Microwave Door Problem (Microwave Repair)
by pogo 1/15/2010 8:52:27 PM(UTC)
Panasonic microwave powers on for just a few seconds (Microwave Repair)
by cheapiejack 10/5/2009 8:12:09 PM(UTC)
(Panasonic) stand-alone microwave-oven turns on upon opening door (Microwave Repair)
by xela 9/27/2008 2:11:22 PM(UTC)
